0 Members and 2 Guests are viewing this topic.
^^^^Wow I really like the final result. It's called ''3M Headlight Lens Restoration System'' right? I must to do it on my two sister's cars : Acura 1.7EL & Nissan Altima SE.My best buddy is a Regional Director for Carquest so I can get all parts & products for super cheap price.
The result looks good. What cause the fogginess? Cause the other light looks perfect.
looks awesome dude!could it have had moisture in it or something? over a long period of time?
before and after result is pretty good, polishing it with too high speed drills easely "burn" the plastic, did you polish by hand?
Did the 3M kit only have polish, or did it have some sort of wax to put on afterwards? I think part of the thing that prevents headlights from fogging/yellowing is a stock coating that filters UV. I've heard that headlights will yellow quicker once that coating is gone. Then again, your coating may have already been gone for some reason, hence the initial fogginess
Ah ok. Well here's to hoping that it will last a long time.Apparently you can get plastic sealants for UV protection (according to this site). Might be good to look into.
Interesting, I might try and pick some up at the local car parts store. Thanks Slusbe.
^^^^Wow only 380 miles. You should put a licence plate in front of your car saying your other vehicule is an CRJ or ATR.
