600+ hp in a miata is pretty unstreetable. You cannot cram enough rubber under one without going with a shortened solid rear axle. 400ish HP is much more usable, and I can achieve that with a much more sensible turbo. To get the 600ish hp you have to use a pretty large turbo (modded SC61 in the last cars sake) and it was a bit laggy. Also to hold anything reliably above 400hp you have to use a stronger tranny and rear diff, I would prefer not to have to go through the cost and time of converting another miata to a RX-7 tranny. I remember I could be cruising at 80 down the freeway and go down a couple gears and start smoking the tires in the last car, I want something a little more usable this time around. The last car was a interesting achievement, but for a daily driven car, it was not the best!
