"By failing to prepare, you are preparing to fail."(Benjamin Franklin - 1706-1790)
To answer a few questions:Brembo - not sure on the exact pressure yet, but it will not be a low boost job. The engine will be re-built. I am not going to increase the capacity to 1800cc as that would mean increasing the bore from 80mm to 83mm. This means reducing the gap between bores in the block by 3mm which are already pretty tight.The pistons will be made by JE Pistons (as are Toby's) http://www.jepistons.com/. I have a well regarded engine builder coming to the workshop to work on it for a day. Absolute gold dust, as modifying the internals of my engine are well beyond my capabilities.I am going for the GT28RS to minimise effects of lag and bring in more boost lower down the rpm range. The torque of the FRP is a little lacking (it is only a 1.7!), so this is where I am going to focus.As to diffs, it is running the optional extra (and pretty damn rare) FRP LSD. The engine will be built to cope with a lot more than 250bhp - in fact I am looking into having several different maps for different power outputs as the Motec M4 Pro ECU can deal with that. The only problem is that I have to stop every time I want to change map - a pain if I find an exotic I fancy taking on but am stuck in 200bhp mode!
TT - You shall see her in action this summer
I absolutely love this car
Cheers mate - fancy a lift on the Rebel run? Or have you got another vehicle in mind?!?!Dani, the only reason I am going the full length with the Turbo is the fact that I have one or two (well, three actually) very knowledgeable people to help. Mark, who helped me build the car, Toby who has built a reliable 1.7 Turbo and regularly uses it as a sprint car and Mark's good mate who is an engine builder. Between them, we should avoid some of the obvious problems. Again, while cost is obviously a factor, I have not cut any corners to date and I do not intend on starting now....if it costs more to do it properly, so be it - I just get a lot of satisfaction building the car!
