Author Topic: My Audi 90q typ85 (4000q) 450+ Hp  (Read 2551 times)
Offline 90q20vt
  • Newbie
« on: 15-Sep-2009, 09:39:46 »
Hope someone would like an old Audi in here too...
This is the car:
1986 Audi 90 Quattro.
Some History :
Bought the car March 2004, original car.
Used it original for about a year then I mounted a UR Quattro 10vt engine in it.
After some time I mounted Autronic. An accident with a faulty hose on track resulted in an overheated engine.
Found out that I wanted more power and bought a 20vt engine. The plan was 300Hp but as always things changed…
Specs :
Engine
Bottom:
2.2 liter from Audi s2 aby
Forged H-beam Connecting Rods
Original pistons (modified to reduse comp)
UR Quattro flywheel
4 puck clutch
All bearings changed to new in better quality
Complete bottom weight balanced to motorsport spec
Head:
Changed all valve steering
High rate valve springs
Titanium retainers
Audi 7a cams (20v)
Ported an polished
Misc:
Header from vsmotor (www.vsmotor.no)
Turbonetics e50 turbo spec5
Wagner turned inlet
820cc bosch injectors
2 x bosch 044 fuel pumps
10mm fuel lines
Intercooler from iveco
Setrab oil cooler with fan
034motorsport/home made engine / transmission mount (motorsport spec)
MSD ignition (MSD blaster SS, MSD 6a)
Modified distributor from 3b engine
Autronic smc engine management
Mapped by vsmotor
Transmission :
Audi UrS4 5 speed 01e
Brakes :
Front : 328 x28mm brake discs from Ford Focus RS (machined to fit), Audi RS2 (brembo) brake calipers with homemade spacer
Back: Original front discs 256mm (ventilated), Audi urs4 rear calipers
Chassis :
Poly bushings all around
Suspension ++ from www.2bennett.com
2B Coil Program Suspension (For Race Koni's)
Coil program shock adaptor ring/ external adjust (Green)
Hex 2B Coil program adjusting split nut wrench 5 mm
2B racing double adjust/with adaptors
2B Upper strut mount: camber & caster adjustable early small chas..Includes special top hats with needle bearings and hardware
2B Shock Tower brace
Thread in wheel stud 14x1.5x40
Cone seat open end lug nuts
Rims :
ABT 7,5x17 et35 and Compomotive MO 7x17 et 42 (with 5mm spacer in front because of brakes)
« Last Edit: 15-Sep-2009, 10:08:35 by 90q20vt »
85 Audi 90q 520Hk 640Nm
04 Vw Multivan 174Hk Highline
91 Audi S2 Coupe
87 Golf Cab 16v
x way to many vw...
Offline 90q20vt
  • Newbie
« Reply #1 on: 15-Sep-2009, 09:47:37 »
Engine data :
348Kw 526Nm @ 1,5Bar and 98oct
388Kw 641Nm @ 2,0Bar and 102 oct
More images
91 Audi S2 Coupe
87 Golf Cab 16v
x way to many vw...
Offline 90q20vt
  • Newbie
« Reply #2 on: 15-Sep-2009, 10:06:48 »
Even more...
Suspension :
At the track :
Found a crappy video too. Typ 85 90q 20vt test at a closed track....
91 Audi S2 Coupe
87 Golf Cab 16v
x way to many vw...
Offline yeckmohr
  • Country: de
  • taxidriver
    • www.ckphotos.de
Re: My Audi 90q typ85 (4000q) 450+ Hp
« Reply #3 on: 15-Sep-2009, 11:46:05 »
welcome to our forum, nice to see a viking more, i like the old Audi 90, looks like a racing machine, like the RS2 from thomas.
Offline Skaala
  • Country: no
  • Team Viking
« Reply #4 on: 15-Sep-2009, 12:26:46 »
Looks like a minter. You should defenetly join us at the autounion meet at the Nürburgring next year :good:
"In principle, this car is too fast for my thoughts!" (Walter Röhrl about the 600+hp Audi S1 EVO)
"If the M5 is the McLaren F1.. the RS6 is the Bugatti Veyron!" - Tiff Needell
"Though I Fly Through The Valley of Death, I Shall Fear No Evil. For I am at 80,000 Feet and Climbing" - SR-71 test pilot
Offline Saadie
  • Country: pk
  • mhmm
« Reply #5 on: 15-Sep-2009, 13:21:34 »
Welcome :)
nice setup you got there ... you best be sure to join Rebel Run 2010 at the ring!  :good:
Online Thamar
  • Country: vla
  • Dictator
« Reply #6 on: 15-Sep-2009, 13:31:23 »
Thanks again for the ride last weekend! Really enjoyed it!
I can tell you guys, and Brembo will also tell you, this car is fast! 3rd gear was fast enough for me lol. The twisty norwegian roads also add up to it ;) You almost forget to breath under full acceleration...
Drugs, dirty dancing and pounding techno music!
Offline Saadie
  • Country: pk
  • mhmm
« Reply #7 on: 15-Sep-2009, 13:45:50 »
^ ohh so thats the story behind the 3rd gear story in the other tread  :whistle:
Online Thamar
  • Country: vla
  • Dictator
« Reply #8 on: 15-Sep-2009, 17:30:43 »
What story?
Offline 90q20vt
  • Newbie
« Reply #9 on: 15-Sep-2009, 18:05:42 »
To bad we didn't have more racefuel. (and a inboard camera  ;) ) You must take a trip back to norway when we have trackday in the vw-audi club.
But you didn't "brake" so hard in the passenger seat that the vacum hose to the ecu did fall of. Some do that you see.. (Brembo ?)
edit : video from our last track weekend in the vw-audi club
Rudskogen 09 vacn drifting
Tom Rune
« Last Edit: 15-Sep-2009, 18:11:28 by 90q20vt »
91 Audi S2 Coupe
87 Golf Cab 16v
x way to many vw...
Offline steph
  • TAU Princess
  • Country: beno
« Reply #10 on: 15-Sep-2009, 18:07:38 »
 :rofl:
"Add live to your years, not years to your life.”
Offline Saadie
  • Country: pk
  • mhmm
« Reply #11 on: 15-Sep-2009, 18:48:40 »
steph .. you know somehting you are not saying  :lol:
cool video Tom! love the drifts :good: and the sound of the screaming engines  :good:
Offline Smartdriver
    • www.Italiansupercar.net
« Reply #12 on: 15-Sep-2009, 20:13:00 »
Wow, really impressive acceleration!!  :shocked: :D
I love Audi of '80  ;)
Offline TT
  • Country: ch
  • Tackleberry
    • SCS
« Reply #13 on: 15-Sep-2009, 21:22:17 »
I really love such understaded oldbutnotvintage cars!!!  :good:
Offline brembo
  • noob
  • Grandpa
« Reply #14 on: 16-Sep-2009, 02:14:48 »
Tom Rune
Hehe...Well to my defense I was keeping you in your seat while we where going sideways doing 3 digit speeds... ;)
Quote
"By failing to prepare, you are preparing to fail."
(Benjamin Franklin - 1706-1790)
Four rings to rule them all.
Offline brembo
  • noob
  • Grandpa
« Reply #15 on: 16-Sep-2009, 02:16:17 »
Oh btw welcome Tom Rune... :)
Quote
Offline brembo
  • noob
  • Grandpa
« Reply #16 on: 16-Sep-2009, 02:17:42 »
It will be a long drive with this on a trailer behind the towing car as it doesnt have any plates anymore...used the red ones this weekend... ;)
Quote
Offline spanky
« Reply #17 on: 16-Sep-2009, 03:03:19 »
Welcome aboard dude... 350kw is pretty impressive!!!
 :good: :good: looks like it goes hard too!!  :good: :good:
Offline Skaala
  • Country: no
  • Team Viking
« Reply #18 on: 16-Sep-2009, 08:46:34 »
auch...no nordschleife either then....you need normal plates :blush:
Offline mrmojo77
  • Country: fi
« Reply #19 on: 16-Sep-2009, 14:10:36 »
Welcome aboard. Very impressive car you got there! :good:  Thanks for sharing! :D
"Phone sex is like calling a restaurant and asking them to describe their food."
industrious
